Instrumentation and Control Engineering
PLC = Programmable Logic Controller
DCS = Distributed Control System
MPI = Multi Point Interface
DP = Distributed Peripheral
SCADA = Supervisory Control And Data Acquisition
HART = Highway Addressable Remote Transducer
HMI = Human Machine Interface
MMI = Man-Machine Interface
VDU = Visual Display Unit
RIO = Remote Input Output
TCP/IP = Transmission Control Protocol-Internet Protocol
CFC = Continuous Function Chart
SFC = Sequential Function Chart
PID Control = Proportional Integral And Derivative Control
RAM = Random Access Memory
ROM = Read Only Memory
PROM = Programmable Read Only Memory
EPROM = Erasable Programmable Read Only Memory
EEPROM = Electrically Erasable Programmable Read Only Memory
RTD = Resistance Temperature Detector
PT= Pressure Transmitter
DPT= Differential Pressure Transmitter
LT= Level Transmitter
FT= Flow Transmitter
TC= Thermocouple
PG= Pressure Gauge
TG = Temperature Gauge
LG= Level Gauge
I/P Converter= Current to Pressure Converter
AFR= Air Filter Regulator.
SOV= Solenoid Valve
PS= Pressure Switch
PCV= Pressure Control Valve
LCV= Level Control Valve
TCV= Temperature Control Valve
FCV= Flow Control Valve
AI= Analog Input
38.AO= Analog output
DI= digital input
DO= Digital output
AI Module= Analog Input Module or Analog Input Card
AO Module= Analog output Module or Analog Output Card
DI Module= Digital Input Module or Digital Input Card
DO Module= Digital output Module or Digital Output Card
SMPS= Switch Mode Power Supply
NO= Normally Open
NO= Normally Closed
MOV= Motorised Valve
TT= Temperature Transmitter
DT= Draught Transmitter
CV= Control Valve
Mag Flowmeter= Magnetic Flowmeter
Triod Cable= Cable for RTD (Resistance Temperature Detector)
Compensation Cable= Cable for TC (Thermocouple)
PV= Process Variable
CV= Control Variable
SP= Set Point
BFV= Butterfly valve
