Top 30 Instrumentation Questions List for your reference.
Share your answers for the below questions.
Mention the Question number and write your answer.
- How can level control be installed in steam drum for measuring the level of steam drum?
- What is ultrasonic flowmeter?
- Differentiate between ultrasonic flowmeter and radar type flow meter.
- What is the use of temperature compensation?
- What is modbus?
- How signals can be taken through modbus?
- How earthing can be checked?
- How many ohms are required for proper earthing?
- Explain signal isolator.
- Which wiring connection is preferred in motor for industrial use?
- What do you mean by trim?
- How DP Transmitter can be calibrated for crude application in floating roof tank?
- What is the principle of capacitance type level transmitter?
- How process line mpm calculation is done?
- Explain PLC and its types?
- What is procedure on mmwc in to tph?
- How an RTD work, and what volts/current goes to a RTD to measure the resistance?
- What is consistency transmitter and describe its working?
- How to calculate MMWC values into tonnes?
- How can I make calculation to Install level transmitter (DP) for open tank and close tank?
- What is difference between DO and DI?
- What is loop1 and loop2 in MTS LT?
- How to calibration a control valve?
- What is dry leg calibration and where is it used?
- How flow can be measured with DP?
- Why MMWC unit is used?
- How HART protocol can be connected with control valves?
- What is the meaning of slope in PH transmitter?
- What is Difference between PLC, DCS and CNC?
- If we have 450 mm height boiler drum level, so what is span & zero value for a dpt transmitter?
