Define terms associated with instrumentation
Describe the major process variables controlled in the Process Industry
Explain the relationship among common process variables
Define terms associated with pressure and pressure instruments
Define terms associated temperature and temperature instruments
Describe the effect heat energy has on the movement of molecules
Describe the purpose and operation of various temperature-sensing/measurement devices used in the process industry
Define terms associated with level and level instruments
Identify the most common types of level-sensing measuring devices used in the process industry
Identify the most common types of flow-sensing measuring devices used in the process industry
Describe the purpose and operation of flow-sensing measurement devices used in process industry
Identify the most common types of analytical devices used in the process industry
Discuss how analytical instrumentation affects the role of the process technician and how the process technician affects the operation of the analytical instrumentation
Identify common types of miscellaneous measuring devices
Explain the components and function of a control loop
Describe the relationship between the measuring instruments (pressure, temperature, level, and flow) and their role in the overall control loop process
Given a simulator or actual device, identify if a control loop is in control or out of control and identify the information used to make the decision
Define terms associated with valves and other final control elements
Given a drawing or actual device, identify the main components of a control valve
Compare and contrast a spring and diaphragm actuator to a cylinder actuator
Given a drawing or actual device, identify and describe and following: current to pneumatic transducer and indications of a sticking control valve
Describe the types of petrochemical and refining industry drawings that contain instrumentation.
Describe the lettering and numbering standards based on ISA instrumentation symbols
Describe the standards for line symbols
Compare and contrast P&IDs and PFDs
Sketch instrumentation control loops on available trainer resources
Explain that different facilities have different practices related to process technicians troubleshooting process instruments
Identify typical malfunctions found in primary sensing elements and transmitters
Identify switches, relays and annunciator systems
