Hello Friends, here i am posting about important interview questions which are mostly asked by the all core companies like HONEYWELL, SOLITONTECH , MAHINDRA SATYAM , L&T etc. So please make use of it. All the best!!!
QUESTIONS:
- What are different types of orifice plates? State their uses.
- How do you identify an orifice in the pipeline?
- Why is the orifice tab provided?
- Explain Bernoulli’s theorem. State its application.
- How can a D.P. transmitter be calibrated?
- How is flow measured in square root?
- Name different parts of a pressure gauge. Explain the use of hair spring in the pressure gauge.
ANSWERS:
1. What are different types of orifice plates? State their uses.
Different orifice plates are:
- Concentric
- Segmental
- Eccentric
Concentric: These plates are used for ideal liquid as well as gases and steam service. Concentric holes are present in these plates, thats why it is known as concentric orifice.
Segmental: This plate has hole in the form of segment of the circle. This plate is used for colloidal and sherry flow measurement.
Eccentric: This plate has the eccentric holes. This plate is used in viscous and sherry flow measurement.
2. How do you identify an orifice in the pipeline?
An orifice tab is welded on the orifice plate which extends out of the line giving an indication of the orifice plate.
3.Why is the orifice tab provided?
Following reasons justify for providing orifice tab:
- Indication of orifice plate in a line
- The orifice diameter is marked on it.
- The material of the orifice plate.
- The tag number of the orifice plate.
- To mark the inlet of an orifice.
4. Explain Bernoulli’s theorem. State its application?
Bernoulli’s theorem states that the ‘total energy of a liquid flowing from one point to another remains constant’. It is applicable for non-compressible liquids. For different types of liquid flow Bernoulli’s equation changes.
There is direct proportion between speed of fluid and its dynamic pressure and its kinetic energy. It can be used in various real life situations like measuring pressure on aircraft wing and calibrating the airspeed indicator. It can also be used to low pressure in the venturi tubes present in carburetor.
5. How can a D.P. transmitter be calibrated?
D.P. transmitter can be calibrated using following steps:
- Adjust zero of Xmtrs.
- Perform static pressure test: Give equal pressure on both sides of transmitter. Zero should not shift either side. If the zero shifts then carry out static alignment.
- Perform vacuum test: Apply equal vacuum to both the sides. Zero should not shift.
- Calibration procedure: Give 20 psi air supply to the transmitter and vent L.P. side to atmosphere. Connect output of the instrument to the standard test gauge. Adjust zero. Apply required pressure to the high pressure side and adjust the span. Adjust zero gain if necessary.
6. How is flow measured in square root?
Flow varies directly as the square root of pressure. Thus, F=K of square root of applied pressure. Since this flow varies as the square root of differential pressure. The pressure pen does not directly indicate flow.
Thus flow can be determined by taking the square root of the pen. Assume the pen reads 50% of the chart. So, flow can be calculated using the pen measure in the chart.
7. Name different parts of a pressure gauge. Explain the use of hair spring in the pressure gauge.
Pressure gauge includes following components:
‘C’ type bourdon tube.
Connecting link3. Sector gear
Pinion Gear
Hair spring
Pointer
Dial
Use of hair spring: Hair spring is responsible for controlling torque. It is also used to eliminate any play into linkages.
If you have any doubts ask me by using the reply.
