___ is a linear electronic voltage regulator
A. A regulator that has a ramp voltage at its output
B. A regulator in which the control device is switched on or off, with the duty cycle proportional to the line or load conditions
C. A regulator in which the pass transistor switches from the “off” state to the “on” state
D. A regulator in which the conduction of a control element is varied in direct proportion to the voltage or load current.
Show Answer
Answer: D
