Is one insulation system better than another?
Not necessarily. It depends on the application and the cost benefit to be realized. Higher temperature class insulation systems cost more and larger transformers are more expensive to build.
Therefore, the more expensive insulation systems are more likely to be found in the larger KVA units.
