Mini Din rail LIU is compact in size and can be mounted in a cabinet with other din rail equipment, where Din rail mount enclosures keep the pitching in close proximity to the active equipment it serves and minimizes cable management in the cabinet.
Din rail mount fiber patch panel solve many of the problems installers and integrator have faced when trying to adapt a conventional fiber optic patch panel for use in power, control, SCADA and industrial cabinets. Din rail mount enclosure is used in manufacturing industries to connect plant floor assets to a central control network requires a robust network.
The compact size of the Mini Din rail LIU saves space especially when it is mounted within enclosures or cabinet with other din rail mount equipment.
Din Rail mount enclosures keep the patching in close proximity to the active equipment it serves and minimizes cable connectivity in the cabinet.
Din rail fiber patch panel solve many of the problems installers and integrator have faced when trying to adapt a conventional din rail mount enclosure for use in power, control, SCADA and industrial cabinets.
Din rail mounted fiber patch panel have cable entry from both bottom and top of the enclosure which allows two cables to be secured using a PG 13.5 cable gland.
Din rail fiber optic patch panel is used in manufacturing industries to connect plant floor assets to a central control network requires a robust network. Mini Din rail LIU can be loaded with a variety of adapters like ST, SC, FC and LC. It can support up to 12 ports when fully loaded with adapters.
