Linear Bus Topology Principle
A linear bus topology consists of a main run of cable with a terminator at each end (See fig.). All nodes (file server, workstations, and peripherals) are connected to the linear cable.
Advantages of a Linear Bus Topology
  • Easy to connect a computer or peripheral to a linear bus.
  • Requires less cable length than a star topology.
Disadvantages of a Linear Bus Topology
  • Entire network shuts down if there is a break in the main cable.
  • Terminators are required at both ends of the backbone cable.
  • Difficult to identify the problem if the entire network shuts down.
  • Not meant to be used as a stand-alone solution in a large building.
Types of Network Topologies
