Modbus Master RTU/ASCII Control for .NET
Modbus Master RTU/ASCII Control for .NET (WSMBS) is a powerful and simple to use .Net Control that makes it easy to access data from a Modbus slave device connected to the PC’s serial port. Simply drop the Control on your form and talk to your device with your VB.NET, C# or Managed C++.
See the Quick Start Guide.
The trial version is a full featured version with a 30 min connection limit.
You may redistribute the wsmbt.dll assembly with your application program unlimited without any royalty.
Supported protocol variants:
- Modbus RTU
- Modbus ASCII
SUPPORTED MODBUS FUNCTIONS:
- 01: Read coil status
- 02: Read input status
- 03: Read holding registers
- 04: Read input registers
- 05: Force single coil
- 06: Preset single register
- 15: Force multiple coils
- 16: Preset multiple registers
- 17: Report Slave ID.
- 22: Mask write register
- 23: Read/Write registers
User defined functions:
- Read User Defined Coils
- Read User Defined Registers
- Write User Defined Coils
- Write User Defined Registers
Examples:
C#
Int16[] Registers = new Int16[10];WSMBS.Result Result;Result = wsmbsControl1.ReadHoldingRegisters(1, 0, 10, Registers);
Visual Basic
Dim Registers(10) As ShortDim Result As WSMBS.ResultResult = WsmbtControl1.ReadHoldingRegisters(1, 0, 10, Registers)
C++
array<Int16>^ Registers = gcnew array<Int16>(10);WSMBS::Result Result;Result = wsmbtControl1->ReadHoldingRegisters(1, 0, 10, Registers);
