Modbus with Excel and Visual Basic Software Download (MBAXP) is a powerful and simple to use Modbus ActiveX control that allows Visual Basic, Excel and other OLE Container applications to quickly and easily access data from a Modbus slave device connected to the PC. MBAXP supports both RTU, ASCII modes and TCP/IP connections.
The communication in each instance of MBAXP runs in its own thread. That means: Your program does not stop responding while waiting for Modbus transactions to finish. You can communicate with multiple ports simultaneously.
See the Quick Start Guide.
Supported protocol variants:
- Modbus RTU
- Modbus ASCII
- Modbus TCP/IP
MBAXP Technical Facts and Features:
- Multi-threaded for high data throughput
- Sample applications included
- No runtime fees
- Easy control of RS-485 converters with RTS toggle
- Data types supported: Integer, Long, Float and Double
- Handles multiple ports
- One instance per port
- Event driven
- You get an event whenever a transaction has finished
- Broadcast (slave ID 0)
- ENRON/DANIEL Mode
SUPPORTED MODBUS FUNCTIONS:
- 01: Read coil status
- 02: Read input status
- 03: Read holding registers
- 04: Read input registers
- 05: Force single coil
- 06: Preset single register
- 15: Force multiple coils
- 16: Preset multiple registers
- 23: Read/Write registers
Download Software
