Motor Control Functional Testing
Below is the method of the Motor control functional test
  • set the isolator of the RCU in the field to open position
  • remove the lock out tag out (LOTO), then rack in the feeder and close the isolator on the draw-out unit.
  • measure the incoming voltage, check the phase sequence of the incoming power at field
  • Open the isolator at draw-out unit
  • Closed the isolator at the RCU
  • Closed the isolator at the draw-out unit
  • initiate start at the substation
  • verify the rotation of the motor, if the rotation is correct direction
  • then verify the running signal of the motor if it is link to DCS
  • initiate trip at the substation draw-out unit
  • verify the status of the motor at the field as well as in the DCS
  • reset trip at substation draw-out unit
  • verify again the status in DCS
  • initiate start in the field (RCU)
  • verify the status at DCS, if confirmed running signal
  • then stop the motor at RCU and verify the status in DCS if confirmed
  • Open the isolator in substation draw-unit and rack out
  • Put Lock out tag out (LOTO)
  • Test complete
