Check out the following Multiple Choice Questions on Programmable Logic Controllers (PLC), PLC important questions, PLC quiz questions. programmable logic controller quiz questions,
1.There are three machines, each with its own start and stop buttons. Any two machines may
run at one time (also, any one may run by itself). Each start button is to have a sealing circuit.
Construct a PLC circuit with appropriate interlocking for this problem.
2.Construct a PLC timing circuit that will output (using output O:2/0) a 0.5 second pulse every
two seconds (i.e. on for 0.5s then off for 2s) if a switch (using I:1/0) is closed and a 1 second
pulse every two seconds if the switch is open.
3.Label the following statements as TRUE or FALSE.
Most PLCs have a fixed number of timers __________
Normally closed contacts “invert” the state of the signal they reference __________
PLCs are advantageous for use in fixed-circuit or fixed program operations __________
4.Complete the following statements.
a) PLC process scanning consists of the _______________ scan, _______________ scan
and _______________ scan.
b) _______________ scanning and ________________ scanning are the two methods
(orders) in which PLCs solve ladder logic programs.
