Test your technical skills on Nuclear Power Plant with our objective questions and answers with an online practice examination.
Nuclear Power Plant Objective Questions
The below-mentioned multiple choice questions and answers on Nuclear Power Plant.
For meeting the change in load of the system the control rod adjusted is:
A. safety rod
B. shim rod
C. regulating road
D. None of these
If the reactor is to be used for converting the fertile material to fissionable material:
A. The material to be converted should be placed around the core
B. The core should be placed around the fertile material
C. The material should be inter mixed with the core
D. The material to be converted should be placed at axial ends of the core
In Nuclear Reactor, it is desirable to use reactor core as:
A. Cubical or cylindrical
B. Cubical or spherical
C. Cylindrical or spherical
D. Spherical
The pressurized water reactor (PWR) employ:
A. Light water and natural uranium
B. Heavy water and enriched uranium
C. Light water and enriched uranium
D. None of the above
If natural uranium is used as fuel, the moderator used will be:
A. ordinary water
B. graphite
C. boron
D. heavy water
The enriched uranium consists of approximately:
A. 10% U235 and 90% U238
B. 20% U235 and 80% U238
C. 30% U235 and 70% U238
Share your understandings of these questions with the correct answers.
