Orifice Flow Meter Problems
Orifice Flow Meter Problems that Produce a Warning with Diagnostic Includes -
  • Incorrect Inlet or Throat Diameter Keypad Entry.
  • Two-Phase Flow.
  • Excessive Flow Disturbance Upstream of the Meter.
  • Contamination Build-Up Through the Meter.
  • Blocked Impulse Lines.
  • Saturated & Drifting DP Transmitter.
  • A Buckled Plate
  • A Plate Installed Backwards.
  • A Worn or Damage Orifice Leading Edge.
  • Incorrectly Spanned DP Transmitter, etc
flow rate change from the design and beyond the turn down ration of the FE shall be considered as one of the problems ?
