PI Controllers in Process System
PI controllers are used in many industrial control applications. The main purpose of using Proportional and Integral (PI) in process system is to improve the steady state accuracy of the system without affecting the stability of the system.
Proportional action responds quickly to the error deviation and the integral action will act slowly but offset or remove the steady state error, i.e, it removes the difference between the set point value and actual process value in the plant over a period of time
  • The choice of having PI controller in the process system when:
  • The control system should not be required fast response
  • Systems consists of large disturbances and noise present during the operation of the process system
  • There is only capacitive or inductive energy storage element in the process system
  • There exists large transport delays in the process system
In most of the plant control applications PI or PID controllers are used. Derivative action speeds up the system response by adding a proportional to the rate of change of feedback error. This is consequently vulnerable to the noise in the error signals which can limits the derivative gain.
Lager value of the derivative gains in the controller will leads to instability of the system and also requires higher values of the proportional and integral gains compared to gains required in PI controllers
