Advantages of PID Gas Detection
Relatively low cost detection of a wide range of combustible VOCs, many of which are toxic
Sensitive to PPM levels – be aware of the lowest detectable limit capability
Accurate and linear over sensor detection range; but readings are relative to the gas used for calibration – typically isobutylene
Does not require presence of O2
UV Tube is self-cleaning due to the creation of Ozone by the detector
Limitations of PID Gas Detection
VOCs usually detected by means of broad range sensors
Broad range sensors provide overall reading for general class or group of chemically related contaminants
Unable to identify type of gas being detected
Sensor maintenance may be required
