Good grounding rules include
each PLC component should be grounded back to the main PLC chassis
the ground wire should be separated from power wiring in enclosures
use star washers to ensure good electrical connection
mount ground wires on bare metal, remove paint if needed
use 12AWG stranded copper for PLC equipment grounds and 8AWG stranded copper for enclosure backplate grounds
connect the enclosure to the ground bus
connect the machine ground to the enclosure ground
the ground connection should have little resistance (<0.1 homs is good)
