PLC Hardware Explained
Many PLC configurations are available, even from a single vendor. But, in each of these there are common components and concepts.
PLC Hardware
The most essential components of PLC are power supply, CPU, Input and Output modules, communication modules.
Power Supply
This can be built into the PLC or be an external unit.
Common voltage levels required by the PLC (with and without the power supply) are 24Vdc, 120Vac, 220Vac.
CPU (Central Processing Unit)
This is a computer where ladder logic is stored and processed.
I/O (Input/Output)
A number of input/output terminals must be provided so that the PLC can monitor the process and initiate actions.
Indicator lights
These indicate the status of the PLC including power on, program running, and a fault. These are essential when diagnosing problems.
Configuration of the PLC
The configuration of the PLC refers to the packaging of the components.
Typical configurations are listed below from largest to smallest as shown in below Figure.
Rack
A rack is often large (up to 18” by 30” by 10”) and can hold multiple cards. When necessary, multiple racks can be connected together. These tend to be the highest cost, but also the most flexible and easy to maintain.
Mini
These are smaller than full sized PLC racks, but can have the same IO capacity.
Micro
These units can be as small as a deck of cards. They tend to have fixed quantities of I/O and limited abilities, but costs will be the lowest.
Software
A software based PLC requires a computer with an interface card, but allows the PLC to be connected to sensors and other PLCs across a network.
