PLC Ladder Logic for Auto Lock up system in the Supermarket
Control Purpose:
Once fire or robbery happened in the supermarket, locking up all cash drawers until the alarm situation is cleared.
Devices:
Program Description:
The execution times of FOR~NEXT loop which decide the number of controlled cash counters can be controlled by the value in D0. Each cash counter has 16 drawers. In this program, D0 = K3, which means it can control 48 cash drawers in 3 counters.
F10 = K0, D10F1 represents D10; F10 = K1, D10F1 represents D11; F0 = K2, D10F1 represents D12; F0=K3, D10F1 represents D13.
When the alarm rings, X0 = ON. FOR ~ NEXT loop will be executed for 3 times and HFFFF will be sent to D10 ~ D12 in order. After the execution, the value in D10 ~ D12 will be sent to the external outputs. All the outputs Y will be set to be ON in this case. The system will lock up all the cash drawers.
When the alarm situation is cleared, X0 = OFF. FOR ~ NEXT loop will be executed for 3 times and H0 will be sent to D10 ~ D12 in order. After the execution, the value in D10 ~ D12 will be sent to the external outputs. All the outputs Y will be reset to be OFF in this case. The system will unlock all the cash drawers.
In this program, the index register F1 is used for storing single value in a data stack (series D registers). According to different application situations, users can make use of the data stack for controlling timers or counters.
