Pneumatic cylinder(s) (sometimes known as air cylinders) are mechanical devices which use the power of compressed gas to produce a force in a reciprocating linear motion.
Figure : Operation diagram of a single acting cylinder. The spring (red) can also be outside the cylinder, attached to the item being moved.
forces a piston to move in the desire direction. The piston is a disc or cylinder, and the piston rod transfers the force it develops to the object to be moved.
Engineers sometimes prefer to use pneumatics because they are quieter, cleaner, and do not require large amounts of space for fluid storage.
Because the operating fluid is a gas, leakage from a pneumatic cylinder will not drip out and contaminate the surroundings, making pneumatics more desirable where cleanliness is a requirement.
