A device used to position a valve with regard to a signal. The positioner compares the input signal with a mechanical feed back link from the actuator. It then produces the force necessary to move the actuator output until the mechanical output position feedback corresponds with the pneumatic signal value. Positioners can also be used to modify the action of the valve (reverse acting positioner), alter the stroke or controller input signal (split range positioner), increase the pressure to the valve actuator (amplifying positioner), or alter the control valve flow characteristic (characterised positioner).
