Pressure Sensors Pigtail Siphons
Pigtail Siphons are used for cooling or warming leg for applications where the process temperature is higher or lower than the ‘normal measuring sensor temperature range‘ .
Temperature extremes can cause inaccuracy or decreases the life span of instruments not specifically designed for such severe services application.
Siphone are called as pig tail siphone as they are coiled/rolled up and looks like pig tail.
One of vendor has a siphone
