Quick Opening Valve
A flow characteristic that provides maximum change in flow rate at low travels. The curve is basically linear through the first 40% of travel. It then flattens out indicating little increase in flow rate as travel approaches the wide open position. This decrease occurs when the valve plug travel equals the flow area of the port. This normally happens when the valve characteristics is used for on/off control.
