Resistance thermometer Time Constant
A time constant indicates the responsiveness of a resistance thermometer to temperature change.
A common expression is the time it takes a thermometer to reflect 63.2% of a step temperature change in moving water.
Response speed depends on the mass of the thermometer and the rate at which heat transfers from the outer surface to the sensing element.
A rapid time constant reduces errors in a system subject to rapid temperature changes.
