This term has several different meanings depending upon the device it is describing. A reverse acting actuator is one in which the actuator stem retracts with an increase in diaphragm pressure.
A reverse acting valve is one with a push-down-to-open plug and seat orientation.
A reverse acting positioner or a reverse acting controller outputs a decrease in signal in response to an increase in set point.
