EIght salient parameters must be addressed for every RTD application to ensure the desired performance. Many will be specified by the manufacturer of the instrument to which the rtd will be connected. If it is a custom circuit or special OEM application, the designers must make all the decisions. The four specifications dictated by the instrumentation or circuitry are: sensor material, temperature coefficient, nominal resistance, and to some extent, wiring configuration. Several metals are quite common for use in RTDs and the purity of the metal as well as the element constriction affects its characteristics.
Platinum is by far the most popular due to its near linearity with temperature, wide temperature operating range, and superior long-term stability. Other materials are nickel, copper, balco (an iron-nickel alloy), tungsten, and iridium. Most of these are being replaced with platinum sensors, which are becoming more competitive in price through the wide use of thin film-type resistance elements that require only a very small amount of platinum as compared to a wire-wound element.
