Engineers Community
Siemens PLC upload
PLC
santhosh
June 9, 2020, 5:30am
1
This article describes how to upload the siemens s7-300 PLC project.
Step 1: Create a new project in Simatic Manager Step7 5.5 with proper name and path.
Step 2: Make SET PG/PC setting.
We have so many way depends on type off plc to choose communication protocol list are below
PC Adapter
CP 5512
TCP/IP
TS Adapter
We are use hare PC Adapter its convenient to use
We make the setting hare PC Adapter (MPI)
Select Transmission rate,
MPI address (This is your pg MPI Address not of plc MIP Address )
Step 3: Select PLC & upload PLC Backup
Select PLC option from toolbar
711×485 47.8 KB
Select Upload Station To PG.
Select View :It will display the online PLC select PLC which you want to upload and click on ok
Upload process start
PLC Upload process start
1366×738 26.7 KB
Step 4: Project upload is done
PLC Project upload is done
1366×738 23 KB
