Standard Rack Mounted Fiber Optic Patch Panel
UNISOL Fiber Rack mounted LIU provides cross-connect and interconnects capabilities for splicing & terminating optic fiber cables, pigtails in the fiber access network. Rackmount fiber optic patch and splice enclosures in data cabinets are available pre-loaded with any connector interface required. These 19” 1U rack mount fiber patch panels are ideal for high-density LAN interconnect or cross-connect patching.
These Fiber Rack mounted LIUs are compatible with standard 19” and 23” equipment racks and are designed to accept wireworks, adapter strips, and splice trays or distribution modules. Our rack mount panels are fabricated from 16-gauge mild steel with corrosion-resistant seven tank process powder coating to provide excellent protection for the inside fibers.
The Fiber Rack mounted LIU ears can also be adjusted to 3 different lengths from front to rear for even more flexibility. Each side has large grommet openings for safe horizontal cable routing. Each enclosure is supplied with an accessory pack that includes mounting ears, cable glands, cable ties for cable management, and a cable ID label for the installed cables.
Standard Rack Mounted LIU (2U)
UNISOL 2U Fiber Rack mounted LIU provides cross-connect and interconnects capabilities for splicing & terminating optical fiber cables, pigtails in the fiber access network. Rackmount fiber optic patch and splice enclosures in data cabinets are available pre-loaded with any connector interface required.
These 19″ 2U size rack mount fiber patch panels are ideal for high-density LAN interconnect or cross-connect patching. Unisol’s Highly reliable Fiber patch panels offering user-friendly features that take fiber patching to the next level. Our Fiber [Rack mounted LIUs are designed based on hundreds of customer’s feedback & almost two decades of installation experience of our own expert team.
Fiber Rack mounted LIU is designed with innovative features that make installation and troubleshooting of fiber optic connectivity faster, easier and more cost-effective. These fiber panels are designed for 19” rack mounting with detachable four-panel model and can accommodate 96 fibers in 2U size.
