Star Topology Principle
A star topology is designed with each node (file server, workstations, and peripherals) connected directly to a central network hub, switch, or concentrator (See fig).
Data on a star network passes through the hub, switch, or concentrator before continuing to its destination. The hub, switch, or concentrator manages and controls all functions of the network. It also acts as a repeater for the data flow. This configuration is common with twisted pair cable; however, it can also be used with coaxial cable or fiber optic cable.
Advantages of a Star Topology
  • Easy to install and wire.
  • No disruptions to the network when connecting or removing devices.
  • Easy to detect faults and to remove parts.
Disadvantages of a Star Topology
  • Requires more cable length than a linear topology.
  • If the hub, switch, or concentrator fails, nodes attached are disabled.
  • More expensive than linear bus topologies because of the cost of the hubs, etc.
Types of Network Topologies
