Strain gauge based sensors work on the principle of change in electrical resistance. When, a mechanical element subjects to a tension or a compression the electric resistance of the material changes. This is used to measure the force acted upon the element.
Figure shows a strain gauge load cell. It comprises of cylindrical tube to which strain gauges are attached. A load applied on the top collar of the cylinder compress the strain gauge element which changes its electrical resistance.
Generally strain gauges are used to measure forces up to 10 MN. The non-linearity and repeatability errors of this transducer are ±0.03% and ±0.02% respectively.
