We discuss about Switches Loop Checks Procedure. Switches like Level Switch, Pressure Switch, Temperature Switch loop checks.
Level, Pressure, Temperature Switches Loop Checks
Check and verify the DCS / ESD configuration for applicable points.
Simulate the contact operation (Make / Break) at the switch terminal block and verify the status in the DCS / ESD. However, ESD switch case actual pressure simulation to be provided with hand pump.
ESD hand switches, Start / Stop, Open / Close shall be checked by operating the switch mechanism.
Hand Switches Loop Checks
Power up loop, check contact status as expected.
Check and verify the DCS/SIS configuration for applicable loop.
Hand switches (Including SIS), Start / Stop, Open/Close shall be checked by operating the switch mechanism for both hardware & software switches.
Complete QC documentation and sign off after clearance of punch list items.
