“Temperature is a measure of the amount of heat energy possessed by an object. Because temperature is a relative measurement, scales based on reference points must be used to accurately measure temperature.”
There are three scales of temperature which are widely applied in modern- day science and industry. They are:
- Fahrenheit temperature scale
- Celsius temperature scale
- Kelvin temperature scale
Kelvin temperature scale is not as much popularly used as the Celsius and Fahrenheit scales. However, it finds its major application in the field of scientific researches.
Fahrenheit Temperature Scale
This scale was developed by a renowned physicist named Gabriel Daniel Fahrenheit in the year 1724. It is a non metric temperature scale upon which temperature readings are represented in degree Fahrenheit (ºF). The Fahrenheit scale is most popular in the United States. “Fahrenheit temperature scale is a scale based on 32 for the freezing point of water and 212 for the boiling point of water, the interval between the two being divided into 180 parts.”
Celsius Temperature Scale
This temperature scale was devised by a Swedish astronomer named Anders Celsius in the year 1742. It is a metric temperature scale. It is also sometimes referred to as centigrade temperature scale where centi means one hundred and grade means degrees. Temperature readings on this scale are represented in degree Celsius (ºC). “
The degree Celsius (°C) scale was devised by dividing the range of temperature between the freezing and boiling temperatures of pure water at standard atmospheric conditions into 100 equal parts”. Under this scale, the freezing point of water is 0 ºC whereas its boiling point is 100 ºC. For carrying out scientific experiments, the Celsius scale is preferred over the Fahrenheit scale owing to its better compatibility with the base ten format of the International System i.e. SI of metric measurement. This temperature scale is widely in practice in nearly all parts of the world except United States.
Kelvin Temperature Scale
Kelvin temperature scale was established by a Scottish physicist named Lord William Kelvin in the year 1854. “It is defined as 1/ 273.16 of the triple point (equilibrium among the solid, liquid, and gaseous phases) of pure water. Such a scale has as its zero point absolute zero, the theoretical temperature at which the molecules of a substance have the lowest energy.”
It is considered as the fundamental unit for temperature measurement in thermodynamics field. It is regarded as an international standard for scientific temperature measurement. This temperature scale enables simple expression of numerous physical laws and formulas. The Kelvin scale is an extended version of the Celsius scale. Temperature readings on this scale are represented as positive Kelvin numbers. No negative numbers or degree Kelvins are used for this scale.
Under this scale, the freezing point of water is 273.15 Kelvins whereas its boiling point is 373.15 K. Hence, just like Celsius scale, the Kelvin scale also exhibits a difference of 100 degrees between the freezing and boiling points of water. Kelvins are extremely useful for measurement of very low temperatures involved in scientific experiments.
