The fastest method for transferring data from one register to another is the ___
A. serial transfer
B. parallel transfer
C. hybrid transfer
D. FIFO
Show Answer
Answer: B
Explanation:
In parallel data transfer, multiple bits (often 8 bits or a byte/character) are sent at the same time on different channels within the same cable. This approach allows for the transfer of an entire byte of data simultaneously, from one register to another. This is the fastest method of transferring data between registers because multiple bits are being transferred at once, instead of one after another (as in serial transfer).
The downside is that it requires more data lines (cables/wires), but within a computer system, particularly on a single integrated circuit or within a CPU, the additional lines do not add substantial cost or complexity.
Certainly! The question pertains to the efficiency of different methods for transferring data between registers. Here’s a breakdown of each option:
A. Serial transfer: In serial transfer, data is transferred one bit at a time. While this method is simple and may be suitable for certain applications, it is generally slower compared to parallel transfer because it requires multiple cycles to transfer a full word of data.
B. Parallel transfer: In parallel transfer, all bits of a data word are transferred simultaneously. This means that the transfer occurs in a single cycle, making it significantly faster than serial transfer. Parallel transfer is commonly used in systems where speed is crucial, such as within processors or between integrated circuits.
C. Hybrid transfer: This term is not commonly used in the context of data transfer methods between registers. It’s unclear what specific combination or method this option refers to.
D. FIFO (First-In-First-Out): FIFO is a method for organizing and manipulating a data buffer, not a direct method for transferring data between registers. While it can be used to facilitate data transfer, it is not inherently a transfer method itself.
Given this analysis, the correct answer is indeed B. parallel transfer, as it provides the fastest and most efficient method for transferring data between registers due to the simultaneous transfer of all bits.
