The figure currently depicts normal air supply pressure and an energized solenoid. What will be the valve position following a loss of electrical power to the solenoid ___
Refer to the drawing of a spring-loaded air-operated valve shown in a throttled position (see figure below).
spring-loaded air-operated valve -PG-39
The figure currently depicts normal air supply pressure and an energized solenoid. What will be the valve position following a loss of electrical power to the solenoid?
A. As is
B. More open
C. More closed
D. Varies with system flow
Show Answer
Answer: B
