Adjustable compression fitting are used directly on probe to achieve the required insertion length in the process and to ensure the proper sheathing of probes into thermowell.
Compression fittings for attaching tubing (piping) commonly have ferrules in them.
Compression fittings are popular because they do not require soldering, so they are comparatively quick and easy to use.
