Thermowell Fitting Accessories
Installing temperature sensor assembles into thermowell or directly into the process requires the use of some kind of brass or stainless steel fitting.
Fitting include various threaded unions, bayonet cap (and adapters) and flange.
Adjustable flange can similarly be used to sensor assembly into the process.
Bayonet caps provide a method of quick fitting into suitable adapters located in the process; this technique is widely used in plastics machinery.
Bushes and hexagon plugs are used when adjustment or removal is a lesser consideration.
The choice of fitting may be dictated by the need for pressure integrity or by physical size constraints.
Compression fitting and threaded bushes can be supplied with tapered threads to achieve a pressure tight connection.
