Material for Wells
1 . Stainless steel.
2. Inconel.
3. Monel.
4. Alloy steel.
5. Hastelloy ‘C’.
Material for Wells
2. Inconel.
3. Monel.
4. Alloy steel.
5. Hastelloy ‘C’.
Following are the materials which have been considered suitable for the construction of thermowells all around the world:
Carbon steels: It is the most inexpensive material used in thermowell construction. Owing to its low corrosion resistance its use is limited only to applications where low temperature and stress are involved.
Chrom/Moly steels: These are high strength steels used in pressure vessels and industrial boiler plant.
Stainless steel: It is also a cost effective material for thermowell construction which is mainly used in areas requiring high corrosion and heat resistance. A whole range of stainless steel materials is available in the industry.
Incoloy: It is an alloy made up of nickel, iron and chromium.
Inconel: It is an alloy made up of nickel and chromium.
Monel: It is an alloy made up of nickel and copper.
Hastelloy: It is an alloy made up of nickel, chromium, molybdenum and tungsten which is extremely corrosion resistant.
Haynes alloy: It is a multipurpose alloy which offers high quality resistance to sulphidising, carburising and chlorine bearing environments.
Titanium: This material is very light in weight and offers brilliant strength.
