Valve Body
Generally Control Valves are smaller than line size (recommended not more than two nominal sizes), If required reduced trim may be used to meet the requirement
Valve design is recommended to meet ANSI B16.34 requirement for valves- Flanged, Threaded and welded ends
Face to face dimension is as per ANSI/ISA 75.08.01
Check for IBR applicability
