Test your technical skills on Nuclear Power Plant with our multiple choice questions and answers with an online practice examination.
Nuclear Power Plant Multiple Choice Questions
The below-mentioned multiple choice questions and answers on solar power.
One atomic mass unit (amu) is approximately equals to:
A. 931.4 Mev
B. 251.2 Mev
C. 120.4 Mev
D. 170.5 Mev
Show Answer
Answer: A
In nuclear reactor graphite is used as:
A. fuel
B. coolant
C. moderator
D. electrode
Show Answer
Answer: C
Water in boiling water reactors are used as:
A. coolant
B. moderator
C. both coolant and moderator
D. none of the above
Show Answer
Answer: C
Which of the following materials are fissile:
A. U238 and Th232
B. U238 and Th239
C. U233 and Pu239
D. U238 and Pu239
Show Answer
Answer: C
When the nuclear reactor shuts down why it requires cooling:
A. to cool the reactor from chain reaction
B. to cool the reactor from fission products
C. both (A) and (B)
Show Answer
Answer: C
Which of the reactors are highly stable
A. pressurized water reactors
B. boiling water reactors
C. Pressurized heavy water reactors
D. Fast breeder reactors
Show Answer
Answer: B
Which type of generators are employed in nuclear power plants:
A. salient pole machines
B. non salient pole machines
C. both can be employed
Show Answer
Answer: A
Nuclear power plants always operates as:
A. peak load plants
B. base load plants
C. can be used both base load and peak load plants depends on the requirement
Show Answer
Answer: B
