Turbidity Measurement Principle
Secchi disc :
  • Secchi is opaque circular disc divided into 4 quadrants, alternate quadrants painted black.
  • Disc is attached to cord & lowered until it disappears.
  • The disk is lowered a few more cm and then is slowly raised again until it reappears. This second reading of depth is also noted.
  • The average of these two readings is taken, corresponding depth is called Secchi dept.
  • Higher Secchi dept, more clear water is.
Turbidity tube:
  • It is an alternative to Secchi disk. The length of water column makes pattern disappear is required Secchi depth.
Note:A Siemens star is a device used to test the resolution of optical instruments, printers and displays. It consists of a pattern of bright"spokes" on a dark background that radiate from a common center and become wider as they get further from it. It is useful tool for comparing two printers’ resolutions.
Advantage:
  • Inexpensive
  • Easy and reliable
Disadvantage:
  • Accuracy depends on eyesight of measure r.
  • Quality of water changes with session
  • Need to take multiple reading to improve accuracy.
