Two conducting thin coils X and Y (identical except for a thin cut in coil Y) are placed in a uniform magnetic field which is decreasing at a constant rate.
If the plane of the coils is perpendicular to the field lines, which of the following statement is correct?
As a result, emf is inducted in
A. both the coils.
B. coil Y only.
C. coil X only.
D. none of the two coils
Show Answer
Answer: A
