There are many different types of level indicators, each with its own application.
Transparent level indicators are highly useful in chemical industries and petrochemical fertilizers. As the fluid is stored in high pressure and high temperature, the transparent level indicator is very useful to find the fluid level.
Reflex level indicators are for applications that involve high temperature, high pressure and use of corrosive fluids. The colorless fluid used in this apparatus gives better clarity to level indication.
Magnetic level indicators are red followers that need magnetic level indicators. Cylindrical floats and powerful magnets are used to find the level of the fluid. The float movement is followed by magnetic capsules, and thus, the level in indicated. This type of indicator has good visibility and is absolutely safe to use as it contains non-fragile metal chamber.
