Using Tee connector in Diaphragm
Hello,
Newbie here, Is it allowed to make a tee connection with diaphragm filled with oil (yellow)? My goal is to read the pressure and display the reading into SCADA. It will be a great help. TIA
So, you want to mount both pressure gauge and pressure transmitter with a tee connection.
Technically, yes, it will work.
make sure you provide manifolds for maintenance.
But it is always better to use separate tapping points instead of using a tee joint.
Also, check your company standards.
Thank you vignesh :slight_smile: Now Iā€™m pretty confident.
