Valves are of following types
Control Valve
Isolation or Shutdown Valves
Breather Valves
Pressure Safety Valve (PSV)
Pressure Reducing Valve(PRV)
Choke Valve
Subsurface Safety Valve (SSSV)
Surface Controlled Sub-Surface Safety Valve (SCSSV)
Control Valves
Valve used to regulate the process by varying the flow of process through it by change of opening in it is termed as control valve
Isolation valve
Valve which are intended for use for shutdown in case of emergency or normal operation of maintenance are called Isolation/Shutdown valve. They are also sometimes referred as Actuated On/Off valves as the whole intend behind it use is to shutdown or open the process
Beside various process Design and Operation parameters working on valves following thing need to be taken care:-
Valve body material:- Material selected should be so that it should better or equal to the line material and should be able to handle corrosion errosion if any due to process or arising due to differential created
Failure Position:- Fail position are the position at which valve should attain when their is failure of signal/power/pneumatic supply.This is generally shown on P&ID or given by Process people.
Handwheel Requirment:- Handwheel is manual Operation mode device which is required for emergency services or bypass line services. This is also generally defined by Process people.
Valve Connection:- Special care should be taken for inline instruments such valves etc. Since these valves can be
Flanged
Double Flanged
Wafer Type
Welded
Valve Actuators:-
Valve Accesories
Volume Booster
Trip Valve
Valve Specialties
Extended Bonnets Valve
Bellow Seal bonnet / Double packing
Gas Over Oil Actuator
