Velocity flow measurement techniques allow for the measurement of total flow by measuring the velocity of the fluid within a fixed area duct or pipe. The technique uses a measuring probe to determine the velocity of the fluid in the center portion of the pipe.
It is important to understand that with all fluid flows, there are boundary layer effects at the interface between the walls of the duct or pipe and the fluid flowing through it. For this technique to provide reasonably accurate results, the velocity measurement of the flow must be made well within the duct, to minimize the effects of the boundary layers. For this reason ducts or piles of small diameter typically do not fair well with this technique.
The technique also requires that you be in a laminar flow environment. The results in a turbulent flow area suffer in stability and accuracy. It is possible to calculate the location where the flow in a pipe or duct is fully laminar, but for most applications a general rule of thumb is sufficient. That rule is to make the measurement at least 10 pipe diameters upstream and 20 pipe diameters downstream of any junction, elbow or other flow disturbing point in the pipe.
