Vibration Measurement Basics
  1. Axial Position
  • Thrust Position
  • Rotor Position
  1. Radial Position
  2. Differential Expansion
  3. Case Expansion
  4. Eccentricity
Axial Position
Thrust Position
  • Measurement of the position of the thrust collar in the thrust bearing assembly and how much bearing material may be used up.
  • The probes are mounted on the thrust bearing observing the movement of the rotor position within the thrust bearing.
Rotor Position
Radial Position:
radial posistion
Proximity Probes are used in The X-Y configuration to measure radial vibration, the dc signal from the transducer can be used to indicate the radial position of the rotor within the bearing
Case Expansion
Eccentricity
