In conditions of different designs, the fiber termination box can be classified into a Wall-mounted patch panel and rack-mounted patch panel types.
Wall mount fiber end of contract box is a perfect solution to be used in building access ports, telecommunication closets, main cross-connects, computer rooms, and other managed environments. It is a suitable device for pre-connectarized cables, field unit installation of connectors, and field splicing of pigtails.
Wall-mounted patch panels make the inside fiber optic adapter panels, patch cables, and pigtails realize the function of optical fiber distribution. And they are used for protecting fiber optic cables and connections of pigtails in fiber optic cabling and user terminal applications. The Wall-mounted patch panels are installed on the indoor wall with a terrace that can provide a flexible fiber management system for transiting external device cables to indoor cables and for connector assemblies.
Applications:
- Indore Premise Networks
- Central offices (FTTx)
- Telecommunication Networks
- Security Surveillance Applications
- Process Automation & Control
- Systems
- Power Systems & Controls
Rack-mounted patch panel
The Rack mounted patch panel is intended for cross-associate and interconnects engineering which has interfaces between outside plant links and transmission. The case unit gives space to fiber grafting, conveyance, end, fixing, stockpiling, and administration.
The rack-mounted patch panel is optional with all kinds of fiber optic adapter ports, pre-installed inner trays, and accessories. And fiber optic pigtails of different types are optional, such as SC, FC, ST, LC, E2000, etc. Also, rack-mounted patch panels can be customized by the fiber counts.
Applications:
- Data Centers
- Systems
