What are Flexible Resistance Thermometers?
Unlike thermocouple junctions, which can be welded directly to metal surfaces, resistance thermometers present a certain amount of bulk; and heat losses to ambient air may affect readings.
Small flat elements, such as thin films, may mount on surfaces, but fragile element and lead wire connections make installation difficult.
What%20are%20Flexible%20Resistance%20Thermometers
Figure shows a flexible resistance thermometer with a wire-wound sensing element sandwiched between insulating layers. It conforms closely to sensed surfaces, and has thin insulation to readily transmit heat to the sensing element.
The wire element may be wound to nearly any size to average out temperature gradients, and the flexible construction can withstand extreme shock and vibration.
