Auto Halon cylinder can be discharged manually from the fire & gas control panel in the control room. On initiating the manual release:
The unit shuts down.
The auto Halon cylinder gets discharged in the hood.
Auto Halon discharge confirmation and the auto Halon cylinder pressure low alarm appears on the control panel.
Audible alarm in the control room and siren in the field occurs.
Manual Halon cylinder can be discharged manually from the field through a pall string. On initiating the manual release:
The manual Halon cylinder gets discharged in the hood.
Manual Halon discharge confirmation and the manual Halon cylinder pressure low alarm appears on the control panel.
