What does turndown ratio mean?
Turndown ratio is also commonly referred to as rangeability. It indicates the range in which a flow meter or controller can accurately measure the fluid. In other words, it’s simply the high end of a measurement range compared to the low end, expressed in a ratio and is calculated using a simple formula.
Turndown Ratio = maximum flow / minimum flow
